This video is still being processed. Please check back later and refresh the page.
Uh oh! Something went wrong, please try again.
Automation Pro I On Demand
Learn on demand and self-paced.
rate limit
Code not recognized.
About this course
Welcome
Hello, and welcome to Automation Pro I -- the first step on your automation journey!
This course, designed for learners who have little to zero experience in automation, has helped thousands of learners advance their skills and knowledge in automation.
In this course, you will be introduced to automation and guided through creating your first Workato automation recipe. And, by the end of the course, you will be prepared to take the Automation Pro I certificate exam.
Before you get started, you must sign in using your Workato credentials. Don't have an account? Sign up for a free trial.
Completing the course
Complete each section and take the final exam to earn your "Certificate of Completion" in Automation Pro I.
Introduction to Workato
Start honing your automation skills with basic terminology and concepts related to building recipes.
Recipe components
Get hands on with your first recipe. We’ll guide you through the primary steps, like setting up your trigger, connection, and action.
Introduction to recipe design
These are the nuances that keep your automations clean, flexible, and working most efficiently for you.
Recipe information
Get high-level operational visibility and insight on your team's automations.
Workato community library
Explore a library of community-provided recipes and solutions.
Automation Pro Exam
This is a multiple choice exam designed to be completed in less than 30 minutes. It is an open-book, open-note, open-resource test. By finishing this exam, you will have earned a certificate, and be eligible to join the Automation Pros community as a member. Once you pass the exam, you can submit a request for invitation. After being admitted, you can opt out at any time.
Some character illustrations were provided by StorySet.
Curriculum2 hours
  • Welcome!
  • Course description
  • Course logistics
  • Optional pre-course survey
  • Introduction to Workato
  • The New Automation Mindset
  • Workato at a glance
  • Workato functionality
  • The Workato UI
  • Projects
  • Lab: create a project
  • Knowledge check
  • Recipe components
  • What is a recipe?
  • Application connections
  • Triggers
  • Steps
  • Lab prep
  • Lab: create your first recipe
  • Knowledge check
  • Introduction to recipe design
  • What is recipe design?
  • Data mapping with data pills
  • Formulas
  • Testing and running recipes
  • Lab: map and modify data
  • Knowledge check
  • Recipe information
  • Workato dashboard
  • Recipe details and versions
  • Jobs and job reports
  • Lab: customize a job report
  • Knowledge check
  • Community library
  • Community library
  • Lab: clone a community recipe
  • That's it!
  • Recap and resources
  • Support channels
  • Optional course survey
  • Completion reward
  • Thank you!
About this course
Welcome
Recipe components
Recipe information
Automation Pro Exam
Curriculum2 hours
  • Welcome!
  • Course logistics
  • The Workato UI
  • Projects
  • Knowledge check
  • Recipe components
  • What is a recipe?
  • Triggers
  • Steps
  • Lab prep
  • Knowledge check
  • Formulas
  • Knowledge check
  • Workato dashboard
  • Knowledge check
  • Community library
  • Community library
  • That's it!
  • Support channels
  • Completion reward
  • Thank you!
