This video is still being processed. Please check back later and refresh the page.
Uh oh! Something went wrong, please try again.
Embedded RecipeOps
Build an understanding of potential use cases where the RecipeOps by Workato Connector could be useful for Embedded Partners
Welcome to RecipeOps by Workato for Workato's Embedded Partner.
In this course, you will learn the RecipeOps by Workato connector possibilities. You will also build four recipes that will proactively monitor your customers’ task consumption. These recipes will notify you and the customers of their task consumption. The recipes will also generate an aggregate CSV of your customer's task consumption.
Instructions: You can jump to any topic after starting the course. We encourage you to track your progress through the course sequentially since each topic is designed to lead into the next. Once completed, click the EXIT button on the top right-hand side to end the course. Do not forget to fill in the Survey before exiting.
