The Enterprise Data Hub (EDH) Accelerator
- Installing the EDH Accelerator
Before you start
Install the EDH Accelerator
Configure the EDH Accelerator
Start the EDH recipes
Configure your database tables
Configure your database schema
Configuring additional tables
Verify your validation lookup tables
- Utilizing the EDH Accelerator
Best practices
- Course completion
Recap
Optional course survey
End of course
This video is still being processed. Please check back later and refresh the page.
Uh oh! Something went wrong, please try again.
Enterprise Data Hub
Learn how to harness your core data
Core data (like customers! employees! orders! campaigns!) are c-r-i-t-i-c-a-l for the modern business. Why? Because they power your analytics, process automation, decision rules, data science initiatives, and so. much. more. And that’s where Workato’s Enterprise Data Hub Accelerator comes in—AKA your standardized AND trusted source of truth for critical records. Whether you’re embarking on a customer 360 initiative, creating an employee data/digital marketing hub, this accelerator gives you all the capabilities you need to get up and running—fast. Come and learn more about this accelerator, and how recipes, starter data models, an easy-to-use connector, and configurable schema can transform the way your org works! By the end of this course, you will be able to:
While this course does not have any pre-requisites, we strongly recommend you are familiar with fundamental Workato concepts. You can learn more about Workato basics in our Automation Pro I and Pro II certificate courses. When you are ready to jump-start your automations, click the Get Started button!
Character designs by StorySet. |
