Welcome to HTTP Connector
Course logistics
- Introduction to Workato HTTP Connector
The Workato HTTP Connector 120 min
HTTP Connector vs other Workato connectors
HTTP Connector solutions
Let's check your knowledge!
- Making HTTP connections
Brief API overview
How HTTP Connector communicates with APIs
Base URLs
Lab 1 prep
Lab 1: Connect to an API with HTTP Connector
- Using HTTP Actions
What is an HTTP Action?
Workato HTTP wizard
Lab 2: Create an HTTP Action
Notes on handling errors
- Best practices
New event via polling
Sensitive data
Lab 3: Handle sensitive data with environmental properties
- Course completion
Recap & resources
Optional course survey
Thank you!
HTTP Connector
Learn how to build integration with any HTTP-based API and build custom actions on the Workato platform.
Welcome
Welcome to HTTP Connector by Workato.
This course how to build integration with any HTTP-based API and build custom actions on the Workato platform.
If you are stuck on an integration because of a missing trigger, action, or connector, Workato has platform extensions that enable you to easily build a working trigger or action with minimal work. One of these extensions is the HTTP Connector by Workato.
The HTTP connector allows you to work with any API that supports HTTP connectivity. The HTTP connector works with a variety of auth models, content types, and HTTP methods.
By the end of this course, you will be able to:
Course completion
Complete each lesson and all Knowledge Checks to earn your HTTP Connector Course Badge.
Let's get started!
