- Part 1: Multiple Choice Assessment
60-questions multiple choice assessment
- Part 2: Practicum
Instructions
Submission
Integration Developer Certification
This certification is designed to validate your skills and abilities as a Workato Integration Developer
By clicking the "Accept Terms & Register" button, you are agreeing to the Workato Certification Program Agreement, as well as the restrictions described on this page. This is a comprehensive assessment. This is not a course to prep for this certification. Please consider finishing the Integration Developer learn path prior to attempting this certification process.
What is the Integration Developer Certification?
The Integration Developer Certification is a new certification piloted by Workato and Automation Institute. The goal of this certification is to validate the Workato-specific skills of Integration Developers or similar roles.
What is the benefit of being Workato Integration Developer Certified?
- You'll be one of the first officially certified Workato Integration Developers
- You'll be recognized in Workato Credential Directory
- You'll receive a PDF and digital Certification with easy options to post on LinkedIn
- You'll be considered a better candidate for roles requiring Workato knowledge
What skills is it designed to test?
This certification is designed to validate your skills and abilities as a Workato Integration Developer. Generally, a Workato Integration Developer should have a comprehensive understanding of the Workato platform and be able to create, manage, and troubleshoot Workato integrations. This role should also be able to design Workato solutions to meet specific business needs and integrate multiple systems with different data formats and protocols. Finally, you should be able to apply best practices for integration development and manage integration projects effectively. More specifically, this process is designed to validate your ability to:
- Understand the fundamental concepts of integration development and technical best practices used for successful integrations.
- Know about various data formats and protocols used in integration, such as JSON, REST, and OAuth
- Can use pre-built Workato connectors to connect different systems and applications and understand API design and development.
- Create and test Workato recipes to automate workflows and integrate systems.
- Design Workato solutions to address specific business requirements and integrate multiple systems leveraging modular and extensible methodology.
- Be able to design reliable, scalable, reusable, and fault-tolerant solutions using things like error handling, and reprocessing.
- Develop conditional logic to prevent duplication and handle exceptions between systems.
- Can integrate Workato with databases like mySQL, Amazon RDS, and Snowflake.
- Develop Workato integrations utilizing available data security features.
What does the certification entail?
This certification is done in cohorts. There is limited availability due to the time it takes to grade each submission. You're free to register at any time, but the time your submissions are evaluated by our grading officials depends on when submissions are received on a first-come-first-serve basis. See table below for our current submission status:
February 2024 Cohort | March 2024 Cohort | April 2024 Cohort | May 2024 Cohort | June 2024 Cohort | |
Status |
Cohort Closed
Cohort Closed
Cohort Closed
Accepting Submissions
Cohort Closed
Submissions by | February 15th | March 15th | April 15th | May 15th | June 15th |
Will be graded by | End of February | End of March | End of April | End of May | End of June |
If you pass, you will be awarded the highest difficulty certification Workato has to offer. The process is summarized as follows:
- It's recommended you complete the Integration Developer Learn Path (prep courses) before attempting, which includes Automation Pro I, II, and III.
- Complete and pass a 60-question multiple choice assessment.
- Read through Case Study Scenarios 1 and 2.
- Develop a solution to both case study scenarios.
- Submit your solution assets and a 5 minute video explaining your solution to our team of graders.
How long is the process from start to finish?
As a test-taker, you can complete your submissions in as little as a couple of hours if you're already proficient in the knowledge required to pass the assessment and practical. Once you upload the required materials for the practical submission, you will be queued in a grading cohort for a grading official to evaluate. The date your submission is graded by is subject to the availability indicated by the cohort table above.
Does the certification cost money?
Yes, attempting the certification is $300. You get two attempts for both the assessment and the practicum. If you don't pass either the first time, you get a second chance to pass included as a part of your purchase. If you fail the practicum on the first attempt, a grading official will provide feedback for your additional attempt, and you will be queued for a future cohort depending on the date of your resubmission.
What resources are allowed to be used, referred to, or leveraged in any way while actively taking either the assessment or the practicum?
- The Workato Application
- Workato-provided documentation
- Workato's Youtube channel
- Automation Institute
- Workato.com
- Workato's Product Hub
- Any online properties owned or authored by Workato besides those referenced above unless prohibited by the list below
What resources are not allowed to be used, referred to, or leveraged in any way while actively taking either the assessment or the practicum?
Any materials not owned by Workato explicitly. This includes:
- Any information provided by the internet in any form not supported or owned by Workato
- Recipes available through Workato's community
Additionally, when actively engaged in the practicum or the assessment, the test-taker must not use the guidance of anyone else, in any form, in person or virtually. Workato reserves the right to invalidate or rescind certifications or certification attempts at any time with or without reason and/or refund.
