What are automation accelerators?
Benefits of automation accelerators
Accelerator asset naming conventions
Start your engines!
Recap
Knowledge check
Optional course survey
Course completion
Introduction to Automation Accelerators
Learn about pre-built packages of recipes, connectors, data models, and other assets
Automation Accelerators are pre-packaged solutions which allow you to get started quickly with specific use-cases or larger architectural patterns by leveraging pre-built recipes, connectors, data models, and other assets. These Accelerators can be quickly and easily imported into your Workato environment and come with a comprehensive admin guide to help you configure the solution. By the end of this course, you will be able to:
While this course does not have any pre-requisites, we do recommend you are familiar with fundamental Workato concepts. You can learn more about Workato basics in our Getting Started Guide. When you are ready to jump-start your automations, click the Get Started button!
Character designs by StorySet |
