Course Logistics
- Connector SDK Foundations
Connector SDK Overview
Plan Your Connector
Review
Knowledge Check
- Build Your Connector
The Connector SDK Console
Connector SDK Skeleton and Structure
Define Your Connection
Authentication
Define an Action
Define a Trigger
- Next Steps
Version Control
Release & Share Your Connector
- Course Completion
Recap and Resources
Optional Course Survey
Congratulations!
Introduction to Connector SDK
Learn how to make your first custom connector with Workato SDK
Course Description In this course, you will learn how to build a custom connector with Workato's Connector SDK. Custom connectors can be customized to your team's needs and distributed easily across your organization.
Learning Objectives By the end of this course, you will be able to:
Prerequisites Automation Pro Certificates Before taking this Introduction to Connector SDK course, we highly recommend successful completion of both Automation Pro I and Pro II certificate courses. These courses will give you the foundational understanding of Workato connectors which is necessary to create custom connectors with Workato SDK. Basic Programming Knowledge You will need some basic programming knowledge. In this course, we will encounter basic data structures. We will also utilize arrays and hashes as well as Ruby to manipulate both. You should also be familiar with API endpoints and understand how to read and search within API documentation.
Schedule and Time Commitment This course is self-paced and there are no deadlines. Your progress is saved and you will not lose access to any course material. You can expect to complete the course in about 2 hours, including videos, interactive activities, and exercises.
Let's get started! When you are ready to begin Introduction to Connector SDK, press the Get Started button above. |
