Workato GraphQL Connector
Learn how to deploy the GraphQL universal connector to dynamically read application schema and turn it into an easy to use Workato user interface.
Introducing the Workato GraphQL connector, revolutionizing how you integrate and connect your systems with unparalleled simplicity. It’s another connector of the family of universal connectors. So you can use it to connect to any application that supports GraphQL.
This universal connector dynamically reads the application schema and turns it into an easy to use Workato user interface. No coding, no digging into API docs and no need to learn a new query language. The GraphQL connector takes care of the technical details, you focus on your business problem.
In this video, you will:
- Learn when to use GraphQL
- Learn what is GraphQL
- Examine an example query
- Review input and output fields
- Learn how to create a query and how to reuse existing queries
- Review key benefits of GraphQL
